Hey guys been a while since ive been on here.
Have lost the contact details for Gareth Rowell (Allmon)
He used to work for J-Spec a couple of years ago, but then moved to Toll.
I purchased GTR seats off him but they never got shipped from Japan
If anyone can help me that would be greatly appreciated!
https://www.sau.com.au/forums/topic/394099-help-me-find-this-person/
Forgive me if youve already done this but...
Have you asked J-Spec if they have his details???
Sav - I asked them like 2 yrs ago and they wouldnt give them to me.
Daniel - Shan put me onto him when they both worked at j-spec. I was initially under the impression I was dealing with j-spec. Once he left them I found out this was done on his own behalf.. maybe why he doesnt work there anymore?
Ive tried to get Shan to help but doesnt seem to want to.
Hopefully someone else out there knows him.....
Seriously? The last time I was in contact with Gareth was 2006. I can't even get in touch with him or anyone who keeps in touch with him (yes, even on FB, the option's removed.) We didn't have the most amicable parting either, so I strongly suspect I can't be of any help.
But you already knew all this from our conversations, so I suppose now you're just dragging me into your public post in the hope that I'm holding back some silver bullet of information that will magically return your parts or money or whatever it was you were swindled out of? Many, many years ago you asked me for a parts importer, and I put you onto him, as I knew he did it. He never imported any parts for me, and as far as I knew, he never did it as J-Spec. I wasn't aware how he represented himself to you, or the dealings you had, and I'd assume you guys would have settled whatever matter it was between you as adults, or escalated it to the authorities.
So please, in future, stop insinuating that I'm aiding him, or that I'm withholding information from you.
Now, I've held back from speaking my mind about how you've carried yourself in the thread and in your profile about me, so I'll leave it to your intelligence to work out how it can burn bridges.
put it this way, i had to physically go out to meet him and go with him to an ATM to get my money back in the end.
i have no idea if he's still in Vic, but if you know he works for Toll, why not start there? When's the last time you contacted him? How do you know the seats never left Japan?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
