Holy shit those guys are idiots, i hate to say it but that's not gonna come of in one piece. It'll have to be cut off because a 0.2mm interference fit is tight as f**k. A fit that tight should see the collar heated up, slipped on the crank and left to shrink on.
I shrunk my collar on with a 0.1mm interference and 0.1mm crush on the length, 270rwkw and 7000km's with some pretty hard driving and it hasn't let me down.
this happened to me, years ago.... except we built the engine and ran it like that.
What ended up happening is that the collar wore through the back plate of the timing gear, then that caused the balancer to come lose, the balancer started to flop around and it destroyed itself, also it destroyed the crank, then keyway was screwed in the crank.
Nothing i could to but replace the crank, then the new crank that came back from the same engine builder was the same! the collar was sitting over the crank itself. It was only after looking at the new crank for 1 hour trying to work out what happened when i figured it all out! was pretty happy i did not have to go all around and rip the motor appart again for a third time???
I took it back and asked him just to machine it flat so that collar is flush with the crank, 5 years and 160,000km later and all is still good. (inspected it a couple of months ago)
good work for picking it up, saved yourself alot of cash and time etc etc... mine is not grub screwed, and its still working like a charm..
Looking at one of the photo's close up you can see metal that has burred up and jammed it from them pressing it on so heavily. That tells me two thing: first of all those guys are sloppy, second that the chamfer on the inside diameter of the collar isn't big enough to accommodate the radius i can see on the crank.
With that said i would bet that it's not going to move towards the crank shoulder any more than that so machining the front off leavingabout 0.1mm of overhang on the face for the crank pulley and balancer to tighten down on.
Also make sure they machine back the start of the drive flats so doesn't protrude into the front seal area.
I'm bored so i put this drawing together to explain, you could give it to those drongos to fix it because it looks like they need all the help they can get.
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
