Holy shit those guys are idiots, i hate to say it but that's not gonna come of in one piece. It'll have to be cut off because a 0.2mm interference fit is tight as f**k. A fit that tight should see the collar heated up, slipped on the crank and left to shrink on.
I shrunk my collar on with a 0.1mm interference and 0.1mm crush on the length, 270rwkw and 7000km's with some pretty hard driving and it hasn't let me down.
this happened to me, years ago.... except we built the engine and ran it like that.
What ended up happening is that the collar wore through the back plate of the timing gear, then that caused the balancer to come lose, the balancer started to flop around and it destroyed itself, also it destroyed the crank, then keyway was screwed in the crank.
Nothing i could to but replace the crank, then the new crank that came back from the same engine builder was the same! the collar was sitting over the crank itself. It was only after looking at the new crank for 1 hour trying to work out what happened when i figured it all out! was pretty happy i did not have to go all around and rip the motor appart again for a third time???
I took it back and asked him just to machine it flat so that collar is flush with the crank, 5 years and 160,000km later and all is still good. (inspected it a couple of months ago)
good work for picking it up, saved yourself alot of cash and time etc etc... mine is not grub screwed, and its still working like a charm..
Looking at one of the photo's close up you can see metal that has burred up and jammed it from them pressing it on so heavily. That tells me two thing: first of all those guys are sloppy, second that the chamfer on the inside diameter of the collar isn't big enough to accommodate the radius i can see on the crank.
With that said i would bet that it's not going to move towards the crank shoulder any more than that so machining the front off leavingabout 0.1mm of overhang on the face for the crank pulley and balancer to tighten down on.
Also make sure they machine back the start of the drive flats so doesn't protrude into the front seal area.
I'm bored so i put this drawing together to explain, you could give it to those drongos to fix it because it looks like they need all the help they can get.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
