  • Replies 100
i have someone very interested in the motor possibly picking up this weekend so 5 speed box will be up for sale by itself so... bring on the offers :P
Front discs/calipers $350
Diff $100
Half Shafts $100
Tailshaft $100
Mirrors $30 pair
passenger door window $40
Doors $70 each
Gaurds $60 each
Bonnet $300
Steering Wheel with airbag (minor wear) $150
Passenger air bag $80
Dash $100
Taillights $60 the pair (passengers bottom platics broken)
Stock intercooler with some pipework $50
shell will be available when this running gear is out decent rear hit might rear window n quater windows in it and should be rolling, should be up for a few hundred to get it out my garage :P
crappy weather BUMP :P
full set mint seatbelts $80
good condition carpet $60
stock castors rods, rear camber and toe roads $20 a PAIR!!
2x hicas units $30 each
Airbag steering wheel $130
Pass airbag $80
Dash $100
Cluster 150Km's $60
ALL PRICES NEGOTIABLE!!!!!
if not listed hit me up!!!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
