Switch Underneth Dash On Drvers Side Down By The Throtle 0N Rs4 Stagea 1996?
does any1 no wat this switch does on my rs4 stagea???? its underneth the dash on drivers side by the throtle on the side cover????????
it is the emergency driver ejection button
pls press it.
That's the factory reset button, personally I would never have pushed it.
but it didnt do anything and my car is fine it hasent done anythig to it
at all.
Are you sure?
Must not be modified then... standard tune ect
its just had a s2 rb25det stagea engine put in it cos the old s1 crapd out.
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
    • Sorry, just assumed that talk of coloured pads meant EBC red/green/yellow/shit stuff. I don't know the DBA pads, but it's a reasonable bet that they will be OK. DBA make good stuff generally. Those 4000 series rotors I linked to are very good. I may well replace the RDA rotors I have with those when required.
