Wtb: R31 Front Brakes
Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
lol the 2nd one boss, thank you for pointing this out. I feel as i spend more time here this intro message is some thing i will always make me laugh and shake my head at. Perfect Intro: I have the vehicle
R34DE as in R34 with an RB25DE? So did you get this? Or you planning to? I'm not really sure what you're saying.
