Im selling a 2000 Nissan Skyline ER34 25GTT project car that I purchased last year with plans on finishing it, but have been told that it has to go.
Car has 39,000 Genuine Km's - Full Logbook Service History (Last on the road December 08) and is Dark Blue Pearl (BP9) in color.
(PM me for the car build thread as it is on a different site (No live links allowed))
Car comes with the following parts:
350Z 6 Speed Manual with heavy duty clutch, Extreme flywheel and short shifter. $3750
VQ30DET NEO (30000km on the donk). $3000
2 x Ceramic coated Garrett GT2860RS (-5) Ball Bearing Turbochargers). $3000
Shaved: Boot, door handle locks, boot rear light, rear boot lock & all badges.
Ceramic coating of parts mentioned eg exhaust, turbo's etc. $1400
Custom 4" exhaust system (Same piping used on v8 supercars and NASCARS) with discreet dual tip and Metal Cat high flow cats. Custom Ceramic coated exhaust manifold and dump pipe.(Ceramic coated from dump to cats) [All ceramic coating by Chris at Craved Coatings in a Satin Black finish]. $6000
APS 350Z Twin Turbo Inter-cooler. $1000
Brembo F40 Front Brakes $5000 : - Brembo F40 Calipers
- ENDLESS Brake Pads
- 343x32mm RDD Rotors
- RDD alloy radial mounts
- Braided lines
- Calipers have had a seal kit and have been powder coated gloss black.
Tein Mono Flex Coil over suspension. $3000
Volk CE28N Wheels :- 18 x 9.5" Volk CE28N +22 (Professionally rubbed back, primed and refinished in high quality Glasurit 2 pack with a german clear coat to get the high gloss finish). $4000
Genuine 'Altia' front bumper. Bumper in average condition.
Re-sprayed engine bay and plastic engine cover by Naz @ KMF. $1000
Powder coated rocker covers, coolant pipe and alternator (Silver).
Genuine Nismo RB25DET engine mounts. $500 ea
Factory front guard and engine bolts replaced with hex head bolts.
Re-trimed door trims from cream to black suede. $500
Internal trims (gear shift surround, door switch surrounds, air con, air con vents, etc.) painted satin black.
HKS Half cage. $800
All that remains to be done to be completed, is wiring (Pretty sure the VQ loom is in a box), radiator, seats, drive shaft and engineering. Engine is in but not ready to run, as all the fuel lines and misc parts are in a box.
Manny more parts included, such as a Trust 'Grex' remote oil block adapter, Custom aluminium intake plenum (Unsure of origin). 2 x Spare Heads - Port & Polished. Heavy Duty valve springs. ARP head and main studs. O2 sensors. Gasket set. Old rear suspension and more bits and pieces.
Well over $35000 spent not including the car value.
Asking Price - $40000 ono
Not interested in parting out at this stage. Would like to see it go to a good home and get the attention it deserves.
Not included in the sale is the Focal speakers (As seen in thread).
The vehicle before:
Brakes:
Engine Bay:
Engine, Mounts and Studs:
Turbo's:
Exhaust and Headers:
Gbox:
I/C:
Suspension:
Outer:
Inner:
Heads, Gaskets engine internals:
Custom Ali Intake:
I can be contacted at [email protected], or on 0407 610 133 (Phone not on during working hours but will check after 4.30 PM)
Edited by vadgeviper
https://www.sau.com.au/forums/topic/394659-for-sale-r34gtt/
Obviously the market is quieter than I thought.
Can someone tell me what they think this is worth? Is it because it is no longer a 'true' skyline due to the engine change? Or is it because there is still too much work required?
Cheers
https://www.sau.com.au/forums/topic/394659-for-sale-r34gtt/#findComment-6336942
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
