I dont think stageas (M35 ones anyway) are ugly. But when i seen this i had to put it up and was waiting for the "why would someone put a ugly front on a nice car" sorta phrase.....jetwreck why do you think im putting a stagea nose on a sedan for so it doesnt look like shrek and more like a skyline. The rest of the car is fine
All those bolt on bits are classed as engine mods and ill get defected by the police (because im on my greens) . So they can wait. Suspension is almost done , just waiting on sway bars and links to arrive from japan. New brake rotors, pads abd lines are coming later
Edited by Howaitonaito
The parts are coming together nicely. Would like to thank the following people who have helped me out so far.
Daleo - Front bar.
Chadsta - non turbo radiator and headlight support.
Scotty - Grill.
thanks boys.
Anyone wanting to put a V series nose on their stag (which youd be mad too) will have some cheap parts left over. ie headlights (HiD), bonnet (QX1 white), Grill (chrome), fenders (both pinched by tyres, not bad tho) and radiator support (which fits coupe aswell) all will be going dirt dirt dirt cheap......
Anyone knows of a white stag wrecking PM me, will love you long time ;-P
  • 3 weeks later...
Headlights, guards and bonnet this week. Who ever said it cant be done for under 3k i proved you wrong like i was planning to. You said i couldnt be done well it has.
The final stage is taking the V nose of and fitting the stag nose. There will lots of photos
You must be looking at the wrong tits.
I like 'em perky & firm.
stag front on a n/a 2.5L..... far from perky and firm. more like seeing a big rack in a push up bra.... impressive until you undo the clip and see whats really inside
(just having jokes)
Edited by Deep Dish V35
Yeah, I suppose; gotta start somewhere though.
I'm interested to see what it looks like.
I also encourage boob owners to jam 'em into a push bra; it's like putting chicken salt on hot chips.
Just makes a good thing even better.
if only i could post a picture of the haneous things ive uncovered in past encounters
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
