Hi Guys,
Before u flame i did search and was unable to find solutions to my issue.
Ok well i have just purchased a S1 R33GTST and noticed the following...
It seems like something electrical is causing my rev tacho 'OEM' to jump around like crazy, hopefully this is an common issue and can be sorted without too much fuss, i bang the dash a lil and goes back to normal but i dont like beating my car ahaha.
Also can some1 hook me up in Perth area with some strut braces to suit?
Much thanks,
Smitherines..
https://www.sau.com.au/forums/topic/395943-r33gtst/
Also, check my job on restoring the headlights :-)
Pretty stoked on the outcome.
I originally intended to keep the lights on the car but found 1 had water in it so i baked and re-sealed.
I have coated the lights in 3 x layers of UV protectant to avoid this happening again.
Yellowing = GAY
Edited by HR31DRFT
https://www.sau.com.au/forums/topic/395943-r33gtst/#findComment-6290176
Also, I noticed this plug without any harness going to it>>> ?? WTF!
Has anyone seen anything like this before?
Also found this RSR certificate, whats this? ref pic.
Edited by HR31DRFT
https://www.sau.com.au/forums/topic/395943-r33gtst/#findComment-6290649
Yes it is the throttle sensor, my car runs like sht when im mucking around and forget to plug it in!
you will find some broken wires somewhere unless you have some ecu that dont need it (doubt it)
Also see a vac line missing, there important for proper turbo/inducion operation
Edited by D.I.Y. Mik
https://www.sau.com.au/forums/topic/395943-r33gtst/#findComment-6291050
Next job's to fix...
Rev tacho has finally stopped working totally, so i will remove in the morning and suss out.
The hi-cas light comes on now after about 10mins and stays lit, i have searched around and found that it could be due to the after market boss kit, if anyone has pointers for this help me out please. Tried the diagnose function but couldn't seem to get it in that mode??? help...
But after re-calibrating the TPS the car runs like a hot curry :banana:
Also i will say that it seems i have had no help from many on here which is a little of a let down :thumbsup:
https://www.sau.com.au/forums/topic/395943-r33gtst/#findComment-6292736
Thanks mate, i found this vid the other day and tried to go into diagnosis mode but it didnt do it, i've tried like 10 times... i've just bought the car so i might have a look around n see if the is a there is a tomei hicas lock unit on the hicas unit...
Any reason why no1 is helping me out?
Regarding solder joints, i had the tacho out this morning and couldnt see where solder is used, did you have a rundown of this??
Thanks again.
Oh and i think i know maybe why its not going into diag mode, the after market steering wheel????
Edited by HR31DRFT
https://www.sau.com.au/forums/topic/395943-r33gtst/#findComment-6294886
iirc you may need to get a hicas adapter / boss kit..
it took me a few tries but you have to turn it quickly to engage it.. but if you have done that it could be the steering wheel.. the above video the guy has an aftermarket steering wheel so it may be something else..
the tacho may be a wiring issue also
https://www.sau.com.au/forums/topic/395943-r33gtst/#findComment-6295107
    • Thank you for the feedback bro. Looks like it’ll have to stay off the road till it gets an ecu
    • Only if you do not You will not be able to drive it with any serious load without risk of it pinging, which will either slowly or rapidly kill it, depending on how bad it is.
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
