  • Replies 78
appologies 4 the hijak, it is related though...
I was down JMS way last night and there was a fair bit of action. there was some class out there last night. it was good to see some good action out there. ne1 else out there last night?
can't wait 4 the drift day!
as previously mentioned if it rains (which it will) it will COLD and WINDY as hell out there. Anyone who went a couple of times ago will testify to this. Instead I reckon we should have a late arvo cruise, then grab some dinner somewhere then head to my place for a piss-up with DVDs, 8-ball etc. Please post here or PM me if you are interested and I'll tell you when and where
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
