The 040 is a 225lph pump, while the 044 is a 330lph pump. So the 040 can support 520bhp @ 73.5psi, while the 044 can support 730bhp @ 73.5psi.
The 040 is also an in-tank pump, while the 044 is designed to sit in-line.
The significant difference apart from flow (and I would take after market figures with a grain of salt) is that the 040 has an open end (ie mesh style flat bottom the 044 has a threaded fitting on the bottom.
Both can be mounted in-tank but the 044 needs a sock attached.
I have run a bosch 984 pump intank with 12mm hose to connect the factory sock.
Link to official flow rates and pressures.
http://www.bosch.com.au/content/language1/downloads/fuelpumps.pdf
Edited by wolverine
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
