SR20DET Turbo Package Forsale
Trust TD06L2-20g 8cm housing Brand New Core Not used since recore
Trust Stainless Exhuast Manifold Excellent Cond
Trust Type R 48mm External Wastegate
$2150 For whole package!!
Haltech PS1000
with Sr20 patch loom 1100 del
Edited by ecko
https://www.sau.com.au/forums/topic/396923-greddy-td06-turbo-kit-sr20/
