That's a new one on me. Man I'd love to have the skills to be able to crack/decode FAST data and search for this kind of stuff...
Does fast actually have all the information on a specified vin saved in its database or does it just work off the characters in the Vin/model codes?
  • 5 months later...
Here's something more definitive for reference - from my Nür sales brochure:
Only colours available for the Nürs:
M.spec Nür - 5 colours
Millennium Jade (JW0)
Silica Breath (EY0)
Pearl White (QX1)
Sparkling Silver (WV2)
Pearl Black (GV1)
V.spec II Nür - 6 colours
Bayside Blue (TV2)
Pearl White (QX1)
White (QM1)
Pearl Black (GV1)
Here's a scan from the brochure:
It's not too hard to imagine someone throwing money at Nissan to paint it MNP or some other colour, but those cars would be extremely rare I would think.
Black is the best by the way :P
Silica Breath (EY0)
Pearl White (QX1)
Pearl Black (GV1)
Bayside Blue (TV2)
Pearl White (QX1)
White (QM1)
Pearl Black (GV1)
nice share :-)
From what i could determine.. nismo was respraying cars MNP for a price...no nur's came from the factory with MNP paint...which your brochure confirms.
No worries guys.
Need to get the rest of the brochure interpreted / translated, it details all of the differences for the Nur as well (although I generally know them it's good to have the definitive record from Nissan).
Property of Nissan Corporation Japan:
You gotta love seeing "330kW - 440kW" (signifying kW potential) in a sales brochure for a stock car!
Lmao
But it's the truth 'er understatement - lol
Interesting topic, does anybody out there know how to get in to fast info to get actual numbers on the colours that are left or not accounted for,black,blue,sparkling silver,silica breath, which is prob the rarest colour.
What do you mean get the actual numbers? If you mean to find out how many were built in X colour I don't think that is possible with fast itself. Someone would probably have to write a program that analyses the fast catalogue files and pull the data out of them.
you could type the vin number in one at a time through this site :unsure: :
http://www.epc-data.com/
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
