Hi All..
I really don't want to sell this car, and even ingore wife's plea ..but now I have accepted an offer to work in oversea for 2 years (from March, 2005), and really have to sell.
2002 Imported, 62000KM was on the clock, now 78000KM.
It was total stock when I import back in 2002 ($22000), after years of saving and modified by sounded performance workshop in Sydney / Waterloo, all receipt available for inspection.
Looking for $28500 . Please PM me for detail or email me sidewaymambo at hotmail dot com, PICs available upon request. 0403228883 Phillip
Dyno sheet can be provide upon request
Spec as following:
1995 R33 S1 GTST, Dec built, Burgandy, Manual, regular service every 5000KM Mobil 1 only, timing belt / transmission oil/ LSD oil changed at 75000KM service.
ECU/Engine/Exhaust
Ported Head / valve
TOMEI 264 IN/EX cams
TOMEI adjustable exhaust cam gear
APEXi Power FC with H/C
APEXi RSM + shift light
GREDDY type R Blow Off Valve
GREDDY ProfecB boost controller
GREDDY Oil catch can kit
GREDDY engine oil cooler kit
GREDDY intake plenum
GREDDY Iriway 8 Iridium spark plug
Q45 90mm AFM
Q45 90mm Throttle body
NISMO Oil Cap
TRUST TD06-25g Turbo kit inc:
TD06-25g 16cm^2 Turbo
TRUST No'8 wastegate
TRUST exhaust manifold
TRUST Front pipe
NISMO 550cc Injectors
TOMEI R33 Fuel Pump 250L/H
NISMO Fuel Regulator
TRUST 3" front pipe and high flow catalytic converter
FUJITSUBO Cat-Back Exhaust
Suction and Cooling
APEXi Power Intake
TRUST V-SPL Intercooler kit: 600x300x76
custom stainless steel piping
Drivetrain
C's Quickshift kit
OS Giken twin plate clutch set (new installed by Bel, 500KM only)
NISMO big bore slave cylinder (make twin plate feel like stock)
Handling
TOMEI Brake Master Cylinder Stoper
FET Tower Brace (F)
CUSCO Tower Brace ®
DBA drilled / slotted disks (F,R)
Bendix advance / EBC brake pads (spare)
Motul 600 Racing Brake Fluid
Falken Azenis RT/215, 235(F) 255® 80% meat left
Belstien Shock / Whiteline spring
Section HICAS Lock Bar
Urethene suspension bushes (F&R)
Whiteline Handling pack (Full set)
Interior
APEXi EL Mechanical Boost Gauge
GREDDY Gauge POD
FET Turbo Timer
MOMO Steering Wheel
After market gear knob
Pioneer 5550 MP3 Head Unit
Pioneer 6 1/2" splits Speakers (F)
Pioneer 6" ®
RAZO pedal set
Mongoose M-M80 3 alarm + 3 points immobiliser
Exterior
R33 GT-R Style Front bar
R33 GT-R style front grill
R33 GT-R style bodykit
R33 GT-R Style Rear spoiler
Manaray 17" 6 spokes wheels
It really hurts me when someone spends over $40 000 dollars on a car then sells it for less than the cost of the mods. Mainly because my car doesnt have as many mods and I have spend over $40 000
sidewaymambo, if you ever decide to stock the car out (highly recommended) and sell the bits, let me know, I could be very interested in your brake setup, very, very interested. Even might trade for some stockers with endless pads
Free bump
Thanks, steve..I have set a dealine..if nothng happened..I will stocked the car..and you will on my top list..
do you still got the factory turbo setup with dump pipe, in/ex cams....just a ask..
cheers,
heh we're all in the same boat... I've a $50k R32 GTS-T. Philip is being a good dad these days, so he's selling this awesome R33... i'll probably put my car back to stock too b4 selling next time unless someone is prepared to pay decent money
free bump :)
p.s. don't sell b4 we go EC / wakefield together ! havent run with u yet heheh
  • 1 month later...
  • 2 months later...
I feel sad to put this ads, but that's life..trying to be a good husband / dad..
price updated..
free bump :D
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
