Hi All..
I really don't want to sell this car, and even ingore wife's plea ..but now I have accepted an offer to work in oversea for 2 years (from March, 2005), and really have to sell.
2002 Imported, 62000KM was on the clock, now 78000KM.
It was total stock when I import back in 2002 ($22000), after years of saving and modified by sounded performance workshop in Sydney / Waterloo, all receipt available for inspection.
Looking for $28500 . Please PM me for detail or email me sidewaymambo at hotmail dot com, PICs available upon request. 0403228883 Phillip
Dyno sheet can be provide upon request
Spec as following:
1995 R33 S1 GTST, Dec built, Burgandy, Manual, regular service every 5000KM Mobil 1 only, timing belt / transmission oil/ LSD oil changed at 75000KM service.
ECU/Engine/Exhaust
Ported Head / valve
TOMEI 264 IN/EX cams
TOMEI adjustable exhaust cam gear
APEXi Power FC with H/C
APEXi RSM + shift light
GREDDY type R Blow Off Valve
GREDDY ProfecB boost controller
GREDDY Oil catch can kit
GREDDY engine oil cooler kit
GREDDY intake plenum
GREDDY Iriway 8 Iridium spark plug
Q45 90mm AFM
Q45 90mm Throttle body
NISMO Oil Cap
TRUST TD06-25g Turbo kit inc:
TD06-25g 16cm^2 Turbo
TRUST No'8 wastegate
TRUST exhaust manifold
TRUST Front pipe
NISMO 550cc Injectors
TOMEI R33 Fuel Pump 250L/H
NISMO Fuel Regulator
TRUST 3" front pipe and high flow catalytic converter
FUJITSUBO Cat-Back Exhaust
Suction and Cooling
APEXi Power Intake
TRUST V-SPL Intercooler kit: 600x300x76
custom stainless steel piping
Drivetrain
C's Quickshift kit
OS Giken twin plate clutch set (new installed by Bel, 500KM only)
NISMO big bore slave cylinder (make twin plate feel like stock)
Handling
TOMEI Brake Master Cylinder Stoper
FET Tower Brace (F)
CUSCO Tower Brace ®
DBA drilled / slotted disks (F,R)
Bendix advance / EBC brake pads (spare)
Motul 600 Racing Brake Fluid
Falken Azenis RT/215, 235(F) 255® 80% meat left
Belstien Shock / Whiteline spring
Section HICAS Lock Bar
Urethene suspension bushes (F&R)
Whiteline Handling pack (Full set)
Interior
APEXi EL Mechanical Boost Gauge
GREDDY Gauge POD
FET Turbo Timer
MOMO Steering Wheel
After market gear knob
Pioneer 5550 MP3 Head Unit
Pioneer 6 1/2" splits Speakers (F)
Pioneer 6" ®
RAZO pedal set
Mongoose M-M80 3 alarm + 3 points immobiliser
Exterior
R33 GT-R Style Front bar
R33 GT-R style front grill
R33 GT-R style bodykit
R33 GT-R Style Rear spoiler
Manaray 17" 6 spokes wheels
It really hurts me when someone spends over $40 000 dollars on a car then sells it for less than the cost of the mods. Mainly because my car doesnt have as many mods and I have spend over $40 000
sidewaymambo, if you ever decide to stock the car out (highly recommended) and sell the bits, let me know, I could be very interested in your brake setup, very, very interested. Even might trade for some stockers with endless pads
Free bump
Thanks, steve..I have set a dealine..if nothng happened..I will stocked the car..and you will on my top list..
do you still got the factory turbo setup with dump pipe, in/ex cams....just a ask..
cheers,
heh we're all in the same boat... I've a $50k R32 GTS-T. Philip is being a good dad these days, so he's selling this awesome R33... i'll probably put my car back to stock too b4 selling next time unless someone is prepared to pay decent money
free bump :)
p.s. don't sell b4 we go EC / wakefield together ! havent run with u yet heheh
  • 1 month later...
  • 2 months later...
I feel sad to put this ads, but that's life..trying to be a good husband / dad..
price updated..
free bump :D
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
