That's the resonator.
It stops all the in cabin drone that can happen.
Some people run them without them, but I wouldn't recomend it, plus these Jap exhausts tend to be JUST legal, removing (or not using) a resonator could push you over the limit :):D
J
https://www.sau.com.au/forums/topic/3973-hks-supper-dragger/#findComment-64310
The item you are pointing at is just a resonator its basically just straight through and is fiberglass packed
the photo is basically a cat back system consisting of two resonators and a rear muffler!!(all straight through being a super dragger system!)
MEGA
P.s a converter usually look like this!
https://www.sau.com.au/forums/topic/3973-hks-supper-dragger/#findComment-64320
Is that converter section = the resonator section that I don't have?
If I can't get my hands on that missing section, considering you said it's only straight thru with fibreglass packing, will that be easy to fabricate in local workshop and produce the same level of quietness with the original HKS cat back system?
https://www.sau.com.au/forums/topic/3973-hks-supper-dragger/#findComment-64323
Yes it can be fabricated with ease!! but most exhaust shops have straight through resonators just not HKS brand!!(should be just as quiet!) just make sure you get the ones with the perfirated pipe not fluted (perf looks like someone drilled heaps of holes in it!)and the rest is just a few mandrel bends!(make sure there mandrel bends) and then you should have something just like the HKS brand stuff!!(I know this because I made my own exhaust for my car!!)
MEGA
P.s the converter i showed you was off a RX7 s6
https://www.sau.com.au/forums/topic/3973-hks-supper-dragger/#findComment-64331
Thx MegaGTS4
If I don't want to fabricate a hi-flow or 3" pipe where the resonator section is, does anyone know if I can attach my HKS back part muffler to my factory resonator section without any mods/adapters?
https://www.sau.com.au/forums/topic/3973-hks-supper-dragger/#findComment-64335
you'll probably find your standard exhaust is 2 1/4 inch and the HKS is 3 inch then all you need is a 2 1/4 to 3 inch adapter that can be ordered at any local exhaust shop!(or you could take the car and the muffler to the shop and ask them how much it will cost to get it attached!) the standard system and the 3 inch take the same route!But will not perform as good as a cat back system and might not be as loud!!
MEGA
P.s if you made a flange and welded it to a 3 - 2 1/4 chrome tip you could use this as a reducer to join it to your standard exhaust!(just a thought because you can buy these tips anywhere and just paint it black when your done!)
https://www.sau.com.au/forums/topic/3973-hks-supper-dragger/#findComment-64345
thank's....
I don't want loud tho... that's a real turn off driving a loud car with all the drones... for me, a car should be quiet, so even hi flow exhaust needs to be quiet to win my favour :-)
I'll see how I go with the muffler, I hope I can get it done before next cruize, and if I don't go to tassie on the 27th
https://www.sau.com.au/forums/topic/3973-hks-supper-dragger/#findComment-64349
I've given the exhaust a polish... not perfectly clean tho, the other side of the pic still got some dirty area prob from spray over paint (maybe was taken off a white R33 before??)
What u guys think, I hope it wont be loud coz it's really huge...
https://www.sau.com.au/forums/topic/3973-hks-supper-dragger/#findComment-64508
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
