I would have done a straight swap...considering you'd have to pay $$$ to get your HID converted to halogen anyway.....if you end up being stuck just PM me, I'm in Brisbane too.
Dan
I don't have to pay $$$ to get my HID converted. I have to pay $$$ for a pair of halogen headlights. I can either pay $$$ for the halogens and sell the Xenons for $$$x2 or do a swap with someone plus a cash adjustment of only $$ and not $$$.
Who in their right mind would do a straight swap!? Try getting a pair of Xenons from a wrecker and see how much they cost :)
Fair's fair.
I'd be interested in buying them as I'm contemplating doing an R34 headlight conversion on my R33 Gts-t.
What price would you sell them for straight up?
I think I still have some metal inserts that will allow you to use H1 halogen globes in your xenon housings.
PM me if you're interested and I'll dig around.
Thanks man, but I need the full halogen headlight assy for compliancing. They won't accept a Xenon headlight with a halogen bulb.
U guys realise that a xenon headlight assembly cost 2600 each from Nissan. I know cause i just bought one 2 weeks ago for 1400 at a wrecker. Thats 1400 each, second hand. Hey Rigo if u cant sell it here call some of the Sydney wreckers. I bet u could sell it easy for 1500 a pair. Try powerplay in Sydney they were selling them for 1500 each.
Hmm ... i wrote a reply but it didnt get posted. Just thought u guys should know that Xenons are 2600 each new, i just bought a front left side, second hand 1 for 1400. So Rigo if u dont have any success im sure the wreckers would buy your pair for 1500 quite easily. Last time i checked a stock complete headlight assembly from Nissan is 900 each.
Yeah, I'm gonna sell the lights separately now. I have already sent the car to Sydney for compliancing so won't be doing a swap. I will give a couple of wreckers a call.
Thanks...
  • 3 years later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
