  • Replies 151
hey man
S15 factory rear boot spoler with led's, pewter colour $120
is this the spec r with the triangle brake light?
and can i get a pic of the S15 boot lid and ducktail spoiler?
and before you go shooting me down i actually have an s15 lol
ta
i have a s14 silvia to, the r32 is my daily and s14 is my track car i didnt put s14 down because its not done yet..... i wouldnt be on the website looking at your post if i was not interested in something so will you post pic please
hey man
ta
pics of most parts here -
http://s1116.photobucket.com/albums/k569/jdm7777/
they are brand new. i cbf unpacking them to take pics, they look like normal glass windows except they are light weight lexan material. the door windows have slider kits in them.
New parts:
Mazda Air temp sensor (for PowerFC D-Jetro) (brand new) $120
S14a HKB boss kit with airbag light cancel resistor plug (brand new) $180
S14 'Edge' Side skirts, unpainted white gelcoat (brand new) $250
S14.5 Origin +25mm conversion fenders (brand new) $450
S14 Origin +50mm rear fenders (brand new) $450
S14 light weight fibreglass doors (brand new) $900
S14 Full Lexan window kit (rear window with NACA vents, rear quarters, driver and passenger door windows with slider window kits) (brand new) $1,050
S14 Nismo Super Coppermix TWIN PLATE clutch rated to 670hp, one of the best SR clutches available (brand new) $2,100
used parts:
Greddy engine oil cap $40
S14/S15 Nismo springs and struts (lower than factory, very comfortable on street) $550
S15 JDM factory steering wheel with airbag $250
S15 Hybrid aluminium radiator $250
S15 Stage21 aero front bar (painted blue) $350
S15 boot lid and ducktail spoiler (not separating, duck tail is sikaflex'd and bolted on to boot lid) $300
S15 Alcon front brake kit, monoblock aluminium 4-pot calipers (weigh less than stock calipers!), 335mm 2-piece rotors, Ferrodo DS2500 pads $3200 (new price from PWR is $4300)
S13/180sx TRUST 19 row oil cooler kit, thick quality trust core, for S13/180sx with filter relocator $700
C-west genuine carbon fibre GT-wing, mounted on S15 boot lid, wrapped in matte black vinyl $1,100
Hypertune SR20 low port intake plenum (small dent at one end) + 77mm Hypertune throttle body $1,750 (Hi Octane Direct sell the plenum alone for $1800+ and $600 for the throttle body).. save over $800 off new prices
HKS Super Sequential SQV BOV, genuine HKS, mounted on evo 8/9 hot pipe $300
STACK 8130 dash with sensors and loom $1,800
ATP 'Frank' turbo, with stainless steel manifold, will fit s14/15 SR20det, good for around 240-250rwkw with stock cams. Braided lines included. $1100ono
R34 GTR Cusco Type-40 aluminium strut tower brace $240
R34 GTR C-west N1 front bar (genuine), carbon fibre (painted black), will need respray/minor repairs $750
R34 GTR C-west carbon fibre cannards for N1 bar $350
R34 GTR Nismo dash cluster (black version) (brand new) $700
R34 GTR/GTT Nismo GT LED tail lights $1,200
4x Advan AD08 265/35/18 tyres 99% tread (almost new, less than 300km) travelled $1300
RAYS Nismo LMGT4's white 17 x 9 +22 all round, no tyres, concave spokes, clears GTR brembo and Alcon brakes to 335mm rotor $2,200 firm
RAYS Nismo LMGT4's bronze 18 x 9 +22 all round with Advan v103 sport tyres about 50% tread, concave spokes $2,800
RAYS LE37's Top Secret Limited Edition Gold 18 x 10.5 +15 all round (rare, don't really want to sell these) $4000
SSR Type-C 17 x 9.5 +15 PAIR ONLY, white, average condition for age, no buckles $1100
** can post wheels interstate if needed at buyers cost **
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
