  • Replies 151
  • 4 weeks later...
Bump
New parts:
Mazda Air temp sensor (for PowerFC D-Jetro) (brand new) $120
S14a HKB boss kit with airbag light cancel resistor plug (brand new) $180
S14 'Edge' Side skirts, unpainted white gelcoat (brand new) $250
S14.5 Origin +25mm conversion fenders (brand new) $450
S14 Origin +50mm rear fenders (brand new) $450
S14 light weight fibreglass doors (brand new) $900
S14 Full Lexan window kit (rear window with NACA vents, rear quarters, driver and passenger door windows with slider window kits) (brand new) $1,050
S14 Nismo Super Coppermix TWIN PLATE clutch rated to 670hp, one of the best SR clutches available (brand new) $2,100
used parts:
Greddy engine oil cap $40
S14/S15 Nismo springs and struts (lower than factory, very comfortable on street) $550
S15 factory rear boot spoler with led's, pewter colour $120
S15 JDM factory steering wheel with airbag $250
S15 Hybrid aluminium radiator $250
S15 Stage21 aero front bar (painted blue) $350
S15 boot lid and ducktail spoiler (not separating, duck tail is sikaflex'd and bolted on to boot lid) $300
S15 Alcon front brake kit, monoblock aluminium 4-pot calipers (weigh less than stock calipers!), 335mm 2-piece rotors, Ferrodo DS2500 pads $3200 (new price from PWR is $4300)
S13/180sx TRUST 19 row oil cooler kit, thick quality trust core, for S13/180sx with filter relocator $700
C-west genuine carbon fibre GT-wing, mounted on S15 boot lid, wrapped in matte black vinyl $1,100
Hypertune SR20 low port intake plenum (small dent at one end) + 77mm Hypertune throttle body $1,750 (Hi Octane Direct sell the plenum alone for $1800+ and $600 for the throttle body).. save over $800 off new prices
HKS Super Sequential SQV BOV, genuine HKS, mounted on evo 8/9 hot pipe $300
STACK 8130 dash with sensors and loom $1,800
ATP 'Frank' turbo, with stainless steel manifold, will fit s14/15 SR20det, good for around 240-250rwkw with stock cams. Braided lines included. $1100ono
R34 GTR Cusco Type-40 aluminium strut tower brace $240
R34 GTR C-west N1 front bar (genuine), carbon fibre (painted black), will need respray/minor repairs $750
R34 GTR C-west carbon fibre cannards for N1 bar $350
R34 GTR Nismo dash cluster (black version) (brand new) $700
R34 GTR/GTT Nismo GT LED tail lights $1,200
4x Advan AD08 265/35/18 tyres 99% tread (almost new, less than 300km) travelled $1300
RAYS Nismo LMGT4's white 17 x 9 +22 all round, no tyres, concave spokes, clears GTR brembo and Alcon brakes to 335mm rotor $2,200 firm
RAYS Nismo LMGT4's bronze 18 x 9 +22 all round with Advan v103 sport tyres about 50% tread, concave spokes $2,800
RAYS LE37's Top Secret Limited Edition Gold 18 x 10.5 +15 all round (rare, don't really want to sell these) $4000
SSR Type-C 17 x 9.5 +15 PAIR ONLY, white, average condition for age, no buckles $1100
** can post wheels interstate if needed at buyers cost **
still for sale!
New parts:
used parts:
R34 GTR Nismo dash cluster (black version) (brand new) $700 sold
bump!!!!! Rawwwrr.. buy my shit!
SimonR32 sent you a pm buddy. Not really keen to send interstate, i don't have time to arrange the freight etc. Let me know
Hahaha. Indeed.. But try dealing with 500 low ballers then you may understand the frustration that comes with selling parts on forums.. not so much SAU, but always on nissan silvia.
