hey guys,
I seem to be having a strange issue with my R34 GTR, at first I thought it was coil packs so i pulled them out and couldn’t see a problem with them (looked for cracks)
The problem is intermittent and has a couple of problems which I feel are related to something.
Problems:
- Car is stuttering between 3K RMP and 4K, after it hits 4K the car revs smoothly. I can hear the stutter through the pod filters... almost sounds like the BOV is stuttering or something...
- Sometimes when I put the foot down to 100% throttle the Boost, Revs and speed do not change and just sit there...
could it be coil packs or AFM? I haven’t really started looking yet.. I think ill first clean the AFM, anyone got some cleaning tips?
Cheers,
Dom
https://www.sau.com.au/forums/topic/398640-r34-gtr-afm-or-coilpack-issue/
I had a similar problem which was fuel cut at high revs with black smoke , then eventually became misfire intermitently !
You should take the pods off and spray the AFMs with carbie cleaner , clean pods as well .
Then if problem continues as mine did , replace Coilpacks , i got some genuine Nissan packs for $236 a set , or you can get splitfires , this should help .
Visually looking at the coilpacks does not really say anything , mine looked perfect externally but were stuffed at 65,000 km .
Hope this helps !! :rolleyes:
Don't use carby cleaner on AFMs!
Why not , does carbie cleaner leave a residue ?
K33P UP , i would have a good look at your AFMs , no power after 3k rpm could be a dry soldering joint inside your AFM .
Theres plenty info on this problem on SAU
Edited by NISSAN GTR
thanks guys, ill take a look. if i cant use carby cleaner what else is good to clean the AFM?
i guess if it keep happening after the clean i might buy new AFM first and work my way to coil packs.. sometimes it drives fine for a few days but then plays up for days..
I also have a red ( ! ) in the cluster sometimes and only goes away when the speed goes back down to either below 20kmph or 0.... even if i drive and the light comes on i drop the car into neutral to put the revs back to 1,000 rpm... related maybe? or could that be a problem with ABS? as its the same light as the hand brake
Super cheap auto have a MAF/airflow sensor cleaner spray. Use that to hose out the sensors.
Before you go buying coil packs, I'd suggest pressure testing the intake system from the twin turbo pipe to the intake manifold. If you have a lose clamp or split hose somewhere you'll find it. The miss could be simple over-fueling as a result of an air leak.
You mentioned you could hear the BOV stuttering through your pods? this sounds like what happened to mine and it ended up being the o2 sensors.
This was after I swapped the spark plugs and cleaned the AFM's Still a good idea to clean the AFM's like people already mentioned though.
See my report here:
http://www.skylinesaustralia.com/forums/topic/43095-o2-sensor/page__view__findpost__p__5672340
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
