Hey hows it going, i got a R33 Skyline and it currently aint starting, ive recently replaced the loom as the previous loom was all stripped and some of the wires were making contact, so i decided to replace the loom. However when i replaced the loom the car the car would still not start, but now im wondering is there any fuses or relay's which could make the car not start.
I can hire the car priming and the fuel is going to the injectors, as ive taken the hose off and fuel had come out was it would. But the car just cranks over and its not starting, the timing belt was done recently by a shop in perth called PZP and it was done perfectly but the car ran into a few issues after woulds as it would tend to stall while driving mainly due to fact i think was cause the afm singal wire had a loose connection with the solenoid wire on the loom.
Is there any areas i can check on the car that would cause the car to start, as ive made sure all the wires on the loom were grounded and im currently not sure what to check next.
Any help would be greatly appreciated.
https://www.sau.com.au/forums/topic/398752-r33-loom-fuse-issue-not-starting/
Remove spark plugs and check condition, check for spark while cranking( they might be fouled)
Check ALL intercooler pipes and joiners and make sure they are tight and sealed.
Try disconnecting afm and try to start
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
