hey guys
tonight whilst driving my 32 i noticed that once it comes on boost it starts hesitating/ misfiring abit and a cloud of black smoke out the back. I put $20 of BP 98 in it before hand and thats when i started noticing it and thats the first time it happened, the night before i went on the Antilag cruise and again put fuel in before hand and it had no problems came on power fine and smooth.
the car has splitfire coil packs with standard BOSCH plugs, forward facing plenum with saard injectors and a 35R turbo with 44mm gate
im thinking it could be a bad batch of fuel?? possible coil pack?? and maybe the standard plugs have given up on life and thats causing the drama
it idles fine, drives fine with no misfire but as soon as it creeps up to about 4-4.5rpm as the power comes on thats when it starts to hesitate and misfire, sometimes its not bad then some other times its pretty bad any suggestions????
cheers
https://www.sau.com.au/forums/topic/398852-32-misfiring-hesitating/
Sounds like plugs or coils. When there is a lot of fuel/air going in it blows out the spark. Either gap is too large on the plugs or coils aren't making strong enough spark or spark is going somewhere else instead of to the plugs. If the gap is too large I.e. works ok with smaller gap plugs, then its likely the coils are getting old. Smaller gap is just a temp fix for the inevitable.
well i was gonna put new platinum plugs in and take it for a spin if no real change is there was gonna swap splitfires with my mrs's 32 and see if that makes a change then i can cross a few possible causes off my list
well i had a set of platinums sitting around so i put them in and drove it the hesitation is gone but still has abit of a misfire i looked inside each coil pack when i changed plugs and cylinder 1 coil had a white powdery resedue and the little coil spring inside is like gone and all other coils are clean and have no pwdery stuff in it, and the top of the old plug was powdery and all crapped up, so i have a feeling its a combination of shit plugs which are failing when hot? and a crapped out cylinder one coil pack?
ok so i swapped a whole coil pack assembly for all 6 cylinders and the harness from my mrs's car to mine and took it for a spin, still the same result, like a popping, misfiring sound, doesnt really seem to miss i think i can rule out its a coilpack if mine runs the same with 2 different harnesses, i even swapped the dud looking one with the white shit in it to her car and took hers for a drive and hers ran nicely no miss or hesitation, im going down the lines that the pooping/ miss sound is maybe from the screamer pipe under abit of heavy acceleration??, it doesnt do it all the time when on boost just sometimes through the rev range, might even pay to get plugs with a .8mm gap??
cant swap ignitor pack, i have a series 2 rb25 and the ignitor packs are built into the coil packs and ive swapped all of them and i still got the same result, maybe i need to get plugs with the right gap, whats weird is it ran fine before for ages then it started to play up, i swapped plugs with new platinums, it got alot better but not perfect
  • 5 weeks later...
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
