Hey guys !! Just started my car this weekend after my friday night cruise and the car was Ideling funny. I could actualy hear a small POP sound returning in the plenum. After a few troubleshoot steps I noticed that when I pulled the 6th coil plug or injector plug the car was still ideling the same and still did the pop. all other coils or injector that I disconnect has a direct impact on idle. I have changed all the coil packs one by one, Cleaned my mafs, Checked the plugs and re-gapped them, Changed the Ignitor. I dont thinks its the fuel as the car was running great friday night. When my coil pack change did not work I did a compression test and found all 6 CLY to be 150-155 6th cyl was the best @ 155.
Im kind of out of Ideas here :( Is there a way I can remove the coil of #6 and look if there is actualy a spark ?! All readings in POWER FC look great and I have no TPS probleme it sees IDLE ON and goes off as soon as I play with the throttle a bit. I wish I had a video to show you guys the sound :S
Any help or pointers would be great !!
thanks
They all have a nice brown beige color to them, tho the ceramic on #6 was a bit more black. I have changed them and re-gapped them. Im at the office right now so no acces to pics : (
Do you have stock coil packs? If the spark plugs don't fix it, then I'm sorry to say but you'll have to get a known working set and swap it in.
I tryed stock 26 coil packs working , stock 20 and 25 and I still get the probleme :(
***edit : I have also tryed different wire looms from the Ignitor to the coil packs with different coil packs and still same result
Edited by drpheel
Pull the plug, plug it into the coil pack, sit it on top of the motor with about 1-2mm between the end of the plug and one of the rocker covers, get a mate to start the car for you (turn your turbo timer off first) and see if there's a spark at the plug. You only need the car runnign for 2-3 seconds (no damage will be done when doing this). Perhaps even pull two and compare them. #6 might be sparking but be very weak.
If you have lots of delicious spark, I'd be looking for a fuel problems such as a leaky or blocked injector.
Great ! I had in mind that I could only do that with a standard spark plug wire and distributor ... Il give it a try in the morning :) Tnx for the input
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
