1983 DR30 Skyline RS Turbo ‘Ironmask’
2.0l FJ20ET
5 Speed manual
New Daiken clutch
Midnight Purple
Jenesis Front spoiler extension
15 x 6.5 SSR Formula Mesh Alloys
Cusco Adjustable Camber Tops
Cusco Adjustable Front Strut Brace
Lowered suspension
Hi-flowed FJ20 Turbo (T3)
3” Kakimoto Exhaust (Dump pipe back)
Front mounted intercooler
GREX Oil Cooler with remote oil filter
VL Turbo Fuel Pump
GReddy ‘PRofec A’ Electronic Boost Controller
GReddy Turbo Timer
GReddy Adjustable Pressure Relief Valve
PROF Sheepdog Adjustable Blow-off valve
Pod Filter
Mines Ecu
Kenwood CD/Tuner/Tape
Bride Fixed Race Seat
Half Cage
Pivot Shift Light
Ultra Speed meter
Trial ash tray (best mod)
GReddy 60mm Electronic Boost Gauge (2.0bar)
OMORi 45mm Oil Pressure Gauge
OMORi 45mm Water Temperature Gauge
OMORi 45mm Oil Temperature Gauge
OMORi 60mm Exhaust gauge
Spares:
-R200 LSD
-FJ20 Turbo/Exhaust manifold/dump pipe
-Inlet manifold/throttle body/fuel rail
-Standard FJ20 ECU
Just had low km FJ20 fitted, with compression report.
Will require ADR compliance and rego
$8500
[email protected]
https://www.sau.com.au/forums/topic/39914-fs-purple-dr30-rs/
Bump!
I have personally seen and driven benny's DR30 on numerous occasions since he imported it....A very unique car, it really looks fantastic in the midnight purple -
the pics don't do it justice though, here's some better ones. :)
good luck with the sale benny!
https://www.sau.com.au/forums/topic/39914-fs-purple-dr30-rs/#findComment-822391
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
