Hey guys have this Garrett GT3076R its blown and needs a re core or rebuild
Internal wastgate rear direct bolt on to stock R33/34 etc dump
T3 flange
.63 exhast housing
A/R 60 Anit surge ported front housing
Its blown and i was just going to recore it with a brand new garrett core for $900 but i wont use it now, so someone else can get a cheap setup.
$250 bucks
Located Newcastle i can post it if you like :) pm post or call 0422646961 can MMS pics if you like just looks like a turbo ;)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
