looking for some nice second hand wheels under $1300
drift tek/work/rays etc show me what you got! more dish the better! call me on 0421652234 , I HAVE NO CREDIT SO NO TEXTS UNLESS I DONT ANSWER!
im in Newcastle nsw , also want bigger then 8" wide
cheers
Edited by Savtraxx
https://www.sau.com.au/forums/topic/399284-nice-wheels-under-1300/
i dont own work rims i own weds krenze , i dont like the style , theyre for sale
what makes you think i own work rims?
thought they were work,why dont u paint ur car all one colour first?it will make it look better than a set of rims
my car is one colour , the paint is just fu^$ed...
respray aint cheap
i need to sell my wheels to buy new ones , i cant just sell my wheels , spend it on paint then my car sits on jackstands.... ( or just the jack as i cant afford stands ;) )
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
