R33 GTR COIL HARNESS, HKS DLI & HKS R33 GTR DLI HARNESS.
1. HKS DLI w/ Universal Harness
HKS Part No#: 43001-AK001
Perfect Condition, Not a Scratch on the DLI Box, Universal harness previously used.
Less than 1000kms use, one run in.
2. HKS R33 GTR Plug & Play Harness
HKS Part No#: 4399-SN002
Brand New.
3. R33 GTR Coil Harness
Nissan Part No#: 24079-24U10
Perfect Condition.
Pics: We all know what they look like but available on request to genuinely interested persons.
Asking $850 for the lot.
Contact via PM
More info:
Obviously comes with harness to suit R33 GTR but can be mated up with the following cars using the universal harness.
Upto 8 Outputs (Coilpacks).
Skyline - R32 GTR - BNR32
Skyline - R33 GTR - BCNR33
Silvia - PS13 (Red Top)
Silvia - S14 S1
Silvia - S14 S2
Impreza - GC8/GF8 Ver1-2
Impreza - GC8/GF8 Ver3-4
Impreza - GC8/GF8 Ver5-6
Supra JZA80 S1
Supra MKIII - JZA70
Skyline - R32 GTS-t - HCR32
Silvia - S13 (CA18DET)
EVO - CD9A
EVO II - CE9A
EVO III - CE9A
Mark II S2 - JZX100
Starlet - EP82
Starlet - EP91
Mark II S1 - JZX100
Fairlady - Z32
Supra JZA80-S2
Soarer - 2.5GT-T S1 - JZZ30
Soarer - 2.5GT-T S2 - JZZ30
Mark II - JZX90
Aristo - JZS147
Aristo - JZS161
Mark II - JZX81
Legacy - BD5 I
Legacy - BD5 II
Mark II - JZX110
GTO - Z16A
GTO - Z15A
THIS WILL NOT FIT;
Skyline - R33 GTS-t S2 - ECR33
Skyline - R33 GTS-t S1 - ECR33
Skyline - R34 GTR - BNR34
Skyline - R34 GTT - ER34
Stagea - 25t RS (~98+) - WGC34
Stagea - 25t RS Four (~98+) - WGNC34
Stagea - 25t RS Four (pre 98) - WGNC34
Stagea - 260RS - WGNC34
From what I can tell they are not made anymore (Well they are discontinued from Nengun)
Here is a little description:
"The Twin Power ignition amplifier incorporates both the CDI and transistor method ignition to provide optimum spark duration and maximum voltage output, resulting in crisper throttle response and a smoother engine powerband. The CDI method, capacity discharge ignition, provides maximum voltage by transferring all stored energy in the capacitor to the ignition coil so that the ignition current can buildup quickly, thus making the Twin Power very effective in the higher revs where a normal spark would tend to diminish. This strong rapid spark prevents the high rpm ignition miss that reduces peak power. The transistorized method generates high voltage by using transistors to cut off current to the coil, thus allowing for a long energy discharge. This longer spark duration allows the Twin Power to improve lower RPM throttle response and torque. The combination of the CDI and the transistor method incorporates two distinct systems into one high performance unit, hence the designation of Twin Power. The Twin Power produces a spark output that is typically 1.5-2.5 stronger than of the stock ignition system and consumes about 35% less power input than other ignition amplifiers.
The compact and attractive Twin power unit is constructed of durable anodized aluminum and sealed to prevent moisture corrosion. Universal wiring harnesses are included to aid in installation and mounting. Vehicle Specific wiring harnesses are also available for certain models for easier installation and to support installations that require complex integration.
Dimensions - All Twin Power Units, (except for DLI II), are 91mm (L) x 80mm(W) x 34.5mm (H) and weighs approximately 430g (~15.2oz)
Note: HKS Twin Power Units are not compatible with Non-Resistor Spark Plugs
Combination of transistor ignition type, which improves ignition at low rpm and CDI ignition, which improves ignition at high rpm increase ignition energy itself.
Latest vehicles even normal aspirated engines require spark plugs with higher heat range when intake and exhaust parts are upgraded. Twin Power enables strong spark to start engine and idling will be stable.
Cheers.
Edited by krayzie32
All 3 items are SOLD thanks guys.
Wont be responding to anymore PM's regarding this item.
Edited by krayzie32
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
