1999 Nissan Skyline R34 GTR Vspec, very clean car all over only 56000km
Perfect street car, plenty of power but still looks stock under bonnet and apexi ECV to quiet down exhaust so no cop attention.
Aries forged pistons
Tomei Valve springs
260 tomei cams
HKS cam gears
Tomei 650hp Turbos (Garret 28/60-5 spec)
Port matched turbo manifolds
Bosche 044 fuel pump
Splitfire coilpacks
Nismo 550cc injectors
Nismo airflow meters
Nismo engine mounts
Nismo oil catch can
Blitz boost controller
Apexi Power FC
Kakimoto N1 3.5" exhaust
Mines front pipes (Exhaust note is so crisp, sounds like no other 26 i have heard)
Mines Filter
Nismo twin plate clutch
Cusco camber arms (Front & Rear)
Tein Coilover Suspension
HKS Front slotted rotors
Apexi ECV
JVC Head unit
MB Quart front splits
Lightning audio Amp
Lightning audio 12" subwoofer
Reverse camera
Nismo side skirts
Nismo rear pods
19x10.5 Varrstoen, Volk racing CE28n wheels
265 Federal 595 tyres (Still new)
Car now has custom plates [VSP3C] and Nismo Z-tune bonnet..wont let me upload images so if you want new photos msg me on 0448868384.
Extras: Standard bonnet, suspension, exhaust, camber arms, boot with spoiler and more.
Can vouche for this R34 as i'm in the same town, very tough looking and sounding. Extremely clean and well looked after. Sounds monsterious!
Goodluck Matt!
  • 3 weeks later...
  • 3 weeks later...
G`day,
would you trade for r33 v-spec? running around 270kwaw, bearings done,oil pump, turbos etc. cusco coils, work sp1, xenons headlights. Very nice car, approx 110kms.... willing to give you 30k-35k on top
Regards
[email protected]
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
how did u spin the bearing?
Spun bearings = Oil starvation. I guess the car was either running with higher than factory rev limiter, with high flow oil pump, without oil restrictors or on the limiter for extended period of time with low oil level.
  • 1 month later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
