Sard/Denso 700cc
Condition:
I recently bought these with a djetro kit I am looking to use.
I've already got some injectors, so these are surplus to my needs.
They have limited use, you can see what condition they are in, perfect, came straight out of the motor like this.
Engine they were originally in went pop before it made it even got the chance for long use.
195500-0830
6 of them, with all o-rings and collars.
These are direct replacement and fit the standard GTR rail. These are obviously top feed too :)
Price: $765 Express Posted
  • Replies 40
$750 posted, australia wide. Express.
Can get it out today for you, pm me with your number.
Receive it tomorrow ;)
$675 Express Posted.
I'll be at the LOWDOWN meet on the 30th.
Can bring them down with me if you send me a deposit.
Thanks
$650 Express Posted -
I also have a Mint condition Power FC with hand controller, no scratches. $850
Fitted Twin Z32 AFMs as well, not use - with tomei plugs - $200 each.
Free postage for Sydney people over the next few days, as I will be down in sydney for WTAC.
Send me a pm.
  • 3 weeks later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
