yo my mates just inherited his parents civic 4 door sedan stock as a rock
its one of the newer models
hes not into performance really, just wants to make the car look sweet for cruisin
hes off this afternoon to autobarn to check out some stuff but could anyone give any suggestions of what would be nice for him to get
Main things hes thinking
- Body kit: i have found one civic for sale with a nice mugen bodykit for the sedan but cant seem to find anymore info, if anyone could help with that
- Sound system: probably will just get some package with cool stuff that they suggest
- Wheels: he wants to get some nice new wheels could anyone suggest where to look however not too expensive, maybe second hand if they are in good nick
- Suspension: He wants to lower the car but the problem of having a car thats too low for speed bumps etc is not something he wants
any helpful information would be great
Thanks :rant:
Dale
Edit: Car is in sydney north shore :)
https://www.sau.com.au/forums/topic/39958-modifying-a-civic-sedan-looks-sound/
Backup: With all due respect - and this being a Skyline forum and all - I don't think there will be too many people able to offer constuctive advice as how to non-performance modify a Civic.
Might I suggest checking out the http://forum.hot4s.com.au/ website forum - as many of the members there would be more likely to lend a hand in 'dressing' up a Civic. The Hot4s or AutoSalon magazines would no-doubt feature ads relating to suppliers who would help out your friend.
Do disrespect intended - just pointing you to a better starting point.
Cheers
James
lol this website is for nissan skyline ENTHUSIASTS so you may or may not have a skyline :rant: I know lots of people on here with diff cars so i thought maybe anyone could help with civic
thanks for directing me to that other site
dude, are you sure your friend has a civic ? or are you just trying to cover yourself up ?  :)
and no i dont have a civic.
its quite unbelievable the responses ive got lol
i think the name skylines australia kinda gave it away that it was a skylines website but bein a forum member here i thought sum ppl might have a better idea as i didnt think the flaming would be the same as if i did it elsewhere with ppl i dont know
anyway thanks for URL's guess ill seek help for his civic elsewhere than in the "General" Cars section :cheers:
(this is not a rant !! so i got the point so if anyone does have a civic and can help thanks heaps, as i did get already get help on bodykits for a civic)
I dont think they were really flaming.. i think people just get annoyed that there are people who seem to be search engine retarded. Im sure if I went to google or similar I could find 100 sites about modifying civics within 2 mins.
That was a bit harsh, he has already said he's a member of this site, and just wanted some of out opinions... shouldn't cut him down for this as most true car enthusiasts appreciate all types of cars, and he just thought maybe the educated people of this forum could offer some advice...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
