Hi,
I have a list of spares i have laying around which i no longer need, so their up for sale. I have more pics which i can supply if required.
R32/s13 rear camber arms upper and lower/traction rods (missing adjustment pins) $40
R33 front pair LCA's $150
r32 rear passenger LCA $40
Standard r32 gtst side mount intercooler only with some piping $20
Standard r32 drivers headlight $100
5Zigen/Jasma exhuast rear end $50
RAY's Wheels C-Ultras 2 x 17 x 8.5 +34 & 2 x 17 x 9.5 + 38 $350 with spacers (spacers worth over 150$)
off r32 gtst one wheel has buckle (~$50 to fix) but does not leak any air, great for drifting, they are really light, wont find any rims this light for this price.
Spacers are required to clear brake calipers. will need rubber for all 4.
2 x 25mm spacers 2 x 10mm spacers
Brand NEW BITS:
Uras Handbrake shoes, never been used I paid 250. $200
  • 1 month later...
  • 2 months later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
