Hey,
For sale is my 1982 skyline dr30. Its a quick car and would make a great daily/tack or drifter. It comes with a rwc and has about 5 months rego on it. The engine in it is a fj20et, has a bigger turbo, waste gate, bov, Haltec ECU and puts out 290rwhp. The car has run a 12 second pass on a different suspension set up. Has mesh wheels with almost brand new tyres and no rust! Interior is very clean with an almost prefect dash and centre console and nardi steering wheel! Has adjustable coilovers in the rear and stiff springs in the front.
Im somewhat neg on the price so hit me up. I will look at swaps aswell, pretty keen on a rotary or a datsun (1200, 1600, 510 ect...) or an ae86, anything else feel free to offer worst I can say is no, but please be sensible with the offers. This car would make a perfect drift car or track car; hasn't been thrashed or tracked before.
Number plates will probably come with the car as I have no use for them. The car will have roughly 5 months rego and a RWC. I also have a box of spares to go with the car worth about 500$.
If you have any questions feel free to contact me on 0406756553 or via pm.
Thanks.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
