hey guys,
how do i get rid of the yellow tint on the headlights?
the cars passenger door doesnt work on central locking , what could be the problem?
Anyone knows a mechanic in SA who can fix the radio frequency problem?
I an a 23 year old paying 1800 for insurance with SGIC , any other cheaper insurance companies?
Thats all for now.lol
Thx
https://www.sau.com.au/forums/topic/400814-few-350gt-questions/
You need to replace your door actuators - about $250 each shipped from the USA is the cheapest. If you replace just the drivers side actuator it MAY fix the problem. I need to do mine too.
Go see George and Theo at GT Autosound Glynde - they have worked on V35 stereos before.
I pay $1,200 with Just Car Insurance (and that is a higher than normal premium as I use the car for work, plus have $5k worth of wheels/stereo/extras listed) - but I am rating 1, live in a safe suburb and the car is securely garaged at night. All of those things impact your premium.
Also, go check out www.sausa.com.au - we have 120 members in the club (including 4 x V35s). You should join up! Cruises, track days, car shows, dinners, paintball, we do it all.
As for the headlights, i did mine yesterday and used Turtle Wax Lens Restorer from Autobarn for $33 comes with a full kit that has clear instructions and works very well as you can see. I'm with RACQ insurance and pay upwards of $2k with road side assist comp insurance and some other things. Everything else wouldn't have a clue! goodluck
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
