having a look at speakers today started looking at 3 ways discovered 4 ways??
feel like ive fallen down the rabit hole
can any one explain what the hell an 8 way speaker is and how they acheive this??
example??http://www.amazon.co...s/dp/B0007L8BWQ
https://www.sau.com.au/forums/topic/401003-8-way-speakers-what-is-this-crap/
Its a pair of 4 ways not 8 ways
6x9 suck
And pyle speakers are one step above mexican flea market models on the lower models
just buy some local the cheapness with added shipping and voided warranty will bite you in the ass
4 ways dont sound nice they shreik off the glass on rear decks and hiss in doors from the cheap supertweeters
Keep looking mate you will be much happier
Hey ive seen 2000 watts on 6x 9 flea market spec lol
You can get some beast 6x9 like a digital design type
The 6x9 shape is setup to fail from the start , distortion from the cone shape comes on early it pulls on the surround uneven ( it was designed for lowest cost option to fit a rear deck shape back a long time ago not because they sound good !!! )
A lot of car companies made wonky sizes over the years only now are they asking the car audio companies how to do it , shame the audio decks are heading down a bad path again !! with sizing and intergrated a/c etc
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
