Parting out my project car. Everything has to go. Starting a new thread as the other two got a little messy.
V-spec GTR cluster, 26,000 or 27,000k on ODD, Perfect working order $180.
R32/33 PowerFC with controller, perfect working order, slight mark on hand controller will clean up before sale: $750
R34 GTR V-spec rear diff: great condition. travel less than 45k, $500
Catco 3" high flow cat, brought for $200, very little K used, seeling $80
R34 GTR stock fuel pump, support 280awkw no problems $130
R34 GTT Airbags, driver and passenger: $350
R34 Rear Boot in peal white, some adhesive residual on where the spoiler located, otherwise perfect $230
R34 GTT front seats, good seats, very minor stain on passenger side. $350
R34 GTR Carbon fiber replica rear spoiler, OEM height. $300
R34 GTR tail shaft very good condition. $220
R34 GTR tail light covers, rare item, have put the gtt cover below to prove it is a gtr cover. $200
R34 GTT tail light covers $120
RB26 twin turbo front pipe. 60mm entry and 70mm exit. very good flow. Made in Japan, support 300kw+ no worries $250
Center console. little to no mark. $80
R34 GTR alloy pearl white bonnet. good condition, minor paint chipping at front, $500
GTT OEM rear bumper in pearl white. $150
GTR BOVs and intercooler joiner pipes. $200
GTT front fenders in pearl white, $150 each side
GTT rear seats: Clean seats $40
GTT spoiler: $60
GTT stock wheel with center caps an road worthy tyres. some rash $350
R34 GTR V-spec 6 speed getrag gearbox. comes with front shaft, support and almost new nismo mount. $3800
R34 GTR ABS unit: $100
RB26 OEM engine mount. very little K travel. $50/pair
R32 Thick alloy radiator, used for 1 year $70
RB26 Excedy light weight flywheel and heavy duty clutch. just beded in. use less than a year. still very new, brought at $1400, seeling $800
Price negotiable for most items, .
Item located doncaster east Melbourne.
Call 0433289998 or pm.
Cheers
joe
https://www.sau.com.au/forums/topic/401136-r34-gtr-gtt-parts-clearing-out/
  • 4 weeks later...
  • 1 month later...
Still have.
Fuel Pump.................................100
GTT LHS guard... .....................150
RB26 Excedy H/D Pull Clutch.....400
RB26 light weight F/W................300
ABS............................................100
R32 GTR OEM intercooler.........50
  • 3 months later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
