I went in for my major service about 5000km ago, and the guy told me that i would need a new clutch soon. I have either a push or pull type (not sure which one, but the one that makes the clutch pedal move higher and higher the more worn out it is).
I was just wondering what type of clutch should I get, and where can I get it for the best price?
I have a 98 r34 GTT (manual obviously lol)
I don't take my car to the track or drive is on boost regularly, so basically just for normal driving- so i don't need any high performance race clutch or anything. I'm really noob when it comes to clutches, so if anyone could point me in the right direction, it would be great!!
https://www.sau.com.au/forums/topic/401153-time-for-a-new-clutch/
I'd suggest an Exedy replacement clutch kit. Good value for money.
Have a chat to Kudos motorsports, which is also a forum sponsor.
You could get either a HD kit or an OEM replacement kit. Dont think there is much difference in price between them.
http://www.ebay.com....=item33634b0248
Hope this helps.
Btw, I believe R34 GTT clutch is pull type.
Edited by iwanta34gtr
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
