Hi Guys,
We are now stock the Hardrace range of products for Nissans, Mitsubishi....
Hardrace adjustable front tension rod support bar 1pc S13/180SX $105
Hardrace rear lower subframe support bar/rod S13/S14/S15 $138
Hardrace front roll center adjuster S13/180SX $149
Hardrace billet rear subframe rigid bush collar kit 8pcs S13/S14/S15 $105
Hardrace harden rubber front sway bar end link set 2pcs S13/S14/S15/Z32/R32/R33/R34 $83
Hardrace adjustable rear sway bar 22m with bushing S13 $215
Hardrace adjustable front sway bar 28mm with bushing S13/180SX $215
Hardrace harden rubber rear toe control arm (spherical bearing) set 2pcs S13/Z32/R32 $149
Hardrace harden rubber rear toe control arm set 2pcs S13/Z32/R32 $149
Hardrace TPV reinforced rear sway bar end link 2pcs kit S13/S14/S15/R32/R33/R34 $94
Hardrace harden rubber engine and gearbox mount kit 3pcs S13/S14/S15 $270
Hardrace harden rubber rear traction rod set 2pcs S13/S14/S15/Z32/R32/R33/R34 $138
Hardrace harden rubber OEM replacement inner tie rod end set 2pcs S13/180SX $105
Hardrace spherical bearing rear traction rod set 2pcs S13/S14/S15/Z32/R32/R33/R34 $138
Hardrace spherical bearing super tie rod end set 2pcs S13/180SX $138
Hardrace harden rubber rear upper camber kit 2pcs S13/Z32/R32 $193
Hardrace spherical bearing rear camber kit 2pcs S13/Z32 $193
Hardrace TPV steering racking bushing kit 3pcs S13/180SX $72
Hardrace forged angled super tie rod end set 2pcs S13/180SX $149
Hardrace spherical bearing adjustable full replacement rear lower control arm set 2pcs S13/R32 $710
Hardrace spherical bearing front tension rod set 2pcs S13/180SX/Z32/R32 $193
Hardrace rear roll center adjuster 2pcs S13 $160
Hardrace harden rubber rear adjustable camber arm 2pcs set S14/S15/R33/R34 $193
Hardraca spherical bearing rear adjustable camber kit 2pcs S14/S15/R33/R34 $193
Hardrace harden rubber rear differential support arm bushing 2pcs set EVO 7-9 $88
Hardrace harden rubber stock replacement engine mount inserts 4pcs kit EVO7-9 $215
Hardrace steering rack bushing kit 3pcs EVO7-9 $83
Hardrace sphericla bearing front lower control arm bushes 4pcs kit EVO7-9 $358
Hardrace front roll center adjuster (10mm or 15mm setting) EVO7-9 $248
Hardrace harden rubber rear upper arm bushing kit 4pcs EVO7-9 $116
Hardrace spherical bearing rear upper arm bushing kit 4pcs EVO7-9 $270
Hardrace harden rubber rear trailing arm bushing set 2pcs EVO7-9 $105
Hardrace spherical bearing rear trailing arm bushing set 2pcs EVO7-9 $259
Hardrace harden rubber rear differential member bushing kit 2pcs EVO7-9 (AYC) $83
Hardrace harden rubber rear differential member bushing kit 2pcs EVO7-9 (non- AYC) $83
Hardrace 80A harden rubber front sway bar bushing 2pcs set 26mm front sway bar (06-11 JDM FD2 $32
Hardrace 80A harden rubber front sway bar bushing 2pcs set 28mm front sway bar (06-11 FD1/FD2 $32
Hardrace 80A harden rubber rear sway bar bushing 2pcs set 17mm rear sway bar (06-11 FD1/FD2 C $32
Hardrace 80A harden rubber front sway bar bushing 2pcs set 19mm front sway bar (09-11 Front) $50
Hardrace 80A harden rubber rear stabilizer bar bushing 2/pcs set 09-11 FN2 Civic Type R $39
Rear adjustable upper arm, adjust up to 3.5+/-deg of camber. Spherical Bearing race version $215
Full replacement bushing kit for Australian delivered ED/EF Civic or CRX 28pcs kit $402
Front adjustable upper A arm, adjust up to +/- 3.5deg of camber $292
Rear adjustable upper arm, adjust up to 3.5+/-deg of camber. Harden Rubber $138
Hardrace front upper A arm bushing ( 4pcs ) Harden rubber. Fits EG 92-95, DC2 94-01 $83
Hardrace rear trailing arm bushing set (left and right) Harden rubber to aid rear traction $127
Hardrace roll center adjuster set (left and right) Designed for lowered vehicle with optimum $182
Hardrace front upper A arm bushing set ( left and right ) Race version spherical bearing $171
Hardrace rear trailing arm bushing set (left and right) Race version spherical bearings $380
Hardrace shifter rod bushing for SOHC engined 92-95 EG Civic and 96-00 EK Civic $61
Hardrace front lower control arm bushing set ( left and right ) Harden rubber. Fits EG 92 $105
Many oher Honda products....
**All listed prices are inclusive of gst**
https://www.sau.com.au/forums/topic/401301-hardrace-stockist/
Hardrace Upper Control Arms for V35 Sedan... how much
Is this for the front or back?
this is a pretty out there question but how much for a full r32gts-t suspension catalogue?
You really need to tell us what you want, if you really want the full catalgue call us and we'll work something out
can you get S2000 drive shaft spacers? and how much?
cheers
$195
  • 4 months later...
business must be good as no reply to my post?
Given your around the corner lets try again..
Price on hardrace TPV reinforced rear sway bar end link 2pcs kit S15
Do you offer a complete setup meaning this plus rear sway bar?
  • 3 weeks later...
Apologies for the delayed in response.
Hardrace don't make the R32 upper camber arms
Just jap stock 300zx/R32 hardrace front upper camber arms:
http://justjap.com/store/product.php?productid=20046&cat=&page=1
  • 11 months later...
Pmed,
looking for
SKU
6167-R
Hardrace Rear Upper Adjustable Camber Arms - Nissan S14/S15/R33/R34/C34/C35
Durable Rubber Bush Adjustable Ends not sphrerical.
thanks mate
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
