Shiva,
Try japanparts.com they've got the nismo one and also OEM ones plus other styles and they have a sale on at the moment.
http://www.japanparts.com/db/partslist.php?dealer=5&car=76&middle=2&small=11&page=2
Go get a quote from Nengun on the front Nismo bar Shiva - I guarantee you it will be $1k for the bar, and at least $500 for shipping - and even then you don't have a urethane bar - the oem Nismo bars are fibreglass, which means if you hit them/bottom out hard enough they will crack/break.
If you and Trav are keen on the urethane Nismo bars, I will check with the USA supplier on shipping times, confirm your orders, get you both to transfer the $$ to me, and we will get this happening!
I can't really do anything on rear bars though, as the only way this whole thing works is to buy multiple bars at the same time to combine shipping - I already have a nice D-Max rear bar, so have no need for one.
Hey Andrew, not sure about trav but if u can get one bar that wud be great even a bit extra $$$ is fine. Give me a quote and v will see if trav replies by then.....thnx Andrew....
Yeah if I can get 2 guys interested at $1k delivered to their locality (not sure via what method yet, but obviously I would get the bars sent to me, then rebox them and send to you individually), then I will order asap and they will be here within weeks.
haha yeah man - I couldn't believe what he was writing - and each post got funnier and funnier. Sadly I couldn't fit it all in my sig, but at was all HILARIOUS.
I was sitting here drinking some coke and soon as i read "bigger rims f**ck the engine" i nearly spat it all over my desk. Bahaha that's gold.
Hey Andrew,
I dint hear back from trav and you wanted 3 guys in you buy...i cudnt find anyone....and i did ask you questions about getting just a single bar for myself but you never replied....i need the bar asap as my car is in a mess and i need it fixed....i am happy to get if from anyone as long as it is quick....
I am very sorry it created this thought into you...i was just making sure i dont miss out...regarding the headlight issue, i already told you i was in a financial situation...thought u understood it....please try to now...thanks for your support andrew. you can also enquire to other V guys in brisbane, i did put my car for sale, as people quoted too less price, i pulled it off.....
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
