I've got my Trust DD exhaust up for grabs.
I've decided to make a custom system for maximum ground clearance (my car is 20mm off the floor with kit).
It has been modified, we've removed the two rear flanges and welded it to make it one piece.
I did a quick restore on it, removing rust and gave it a fresh coat of paint.
3 inch single exiting out to 2 1/4 pipes. No problems with restrictions as my car made 315kw on 15psi with this setup.
Due to the size, pickup would be best but I am happy to ship at buyers expence.
Price: $400 ono
located in Liverpool region, NSW
PM me!
Adam.
Edited by Run-It-Hard
https://www.sau.com.au/forums/topic/401656-r33-trust-dd-exhaust/
Tips are fine, as you can see in the first photo they are pretty much polished up. There are a few marks and imperfections as you'd expect. It is an exhaust after all.
Does this have the silencers you put in and take out?? Im keen for a good twin outlet system and one I had my eye on fell through, only problem is im in Adelaide.
And this is for 33 2 door i assume?
Edited by rb2534
It doesn't have the silencers unfortunately. Your local autobarn/supercheap would have some though. I don't really like them though, I had one many moons ago and it litterally popped out of the exhaust.
Happy to ship.
Yep for a R33 2 door, It'll fit a 4 door too as the tips come out past the bumper by 20-30mm
  • 3 weeks later...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
