hey guys, i recently bought myself a 1993 R33 series 1? skyline with fairly high KMs 150,000km and as far as i know its stock as a rock with little extras like a exhaust tip apparantly a R34 intercooler? (all i can see is like 2 intercoolers right next to each other and not a FMIC so i think thats what he means..)
when i looked at the engine i noticed the throttle body sensor? on top of the engine was unplugged but they had rewired it ? does anybody know why they would have done this? and my o2 sensor is unplugged and the loom ends are slightly burned from the turbo/cracked but i think i could still plug them in, should i try this? its also missing the front radiator fan which bolts on the front of your radiator but im not sure if i need this since i have the clutch fan plus the "r34" intercooler? correct me if im wrong please...new suspension etc is a given on that year of a model so im fairly sure that needs doing too...
so basically ive been reading up as much as i can on what to do and that and i understand i need new injectors etc before i go putting in a top of the line turbo but what would you guys recommend me doing first so i can safely go ahead and upgrade these things without my engine blowing up? should i get a rebuild first?
i found a bloke whos selling a rb25det which hes done work to for 2800 and im thinking rather than rebuild a engine should i buy a engine which was already being rebuilt and then finish it off? it comes with all parts just needs the plenums etc bolted on and manifolds....then i will need obviously a new ECU/turbo set up..
would that be the cheaper choice in the long run? buy a worked on engine that hasnt been dropped in a car yet? or rebuild as i go along....
in the end i want a 33 which will be reliable, with a bit of guts behind it so i know it will last given im not a dickhead in it...
if any pics of the engine bay are needed just let me know and obviously im a bit of a noob to cars so yeah give me a break lol
This is the engine i was thinking of buying rather than rebuilding my current one
pretty good condition, but to get it up to really good condition i had the head reco'd at the cost of around $600 which included new inlet valve guides and stem seals, the exhaust guides had already been done, while the head was apart i also cleaned up the unnecessary lumps in the exhaust ports.
It all went back together with the following parts:
Performance Springs valve springs and retainers - $300
Camtech 272 Duration, 9mm lift cams - $1200
Tomei adjustable Cam Gears - $300 (not 100% sure i want to sell the cam gears yet)
ARP Head Studs - $150
New Durapro VRS Gasket Kit - $400
ACL Race Series big end bearings - $70
Also to go with this engine is a non-genuine Greddy Front facing plenum which i have gasket matched the runners to the head myself (needed doing really badly), and i have a billet fuel rail kit for this which allows the use of top feed injectors.
Together these cost around $500 and for the right price i can include some GTR Injectors aswell.
It also has a second hand Stainless highmount turbo manifold and Turbosmart 38mm Gate if needed, valued at around $500 for both items together.
As the engine sits it is currently a bare long motor, ready to have manifolds and accessories bolted on and put into use.
Edited by Razon
Jokes, I read the whole thing.
I would say before thinking about new injectors you should look at getting those few issues sorted first. Get yourself a replacement thermo fan, get that sensor and that plug sorted. Then should service the beast, oil, filters, check belts etc. Then get a comp test done, will give an indication as to the condition of the engine, no need to buy a new one if the current one is okay, the RB25s are pretty robust. Then you can start looking at exhaust and a little more boost as well as getting those suspension niggles sorted and go from there, will be able to boost it a safely with the stock turbo, injectors better exhaust. There is a large mods market for the R33, both new and used, so yeah, should be able to get some nice parts cheap.
Send us some picks of that plug and the sensor and the intercooler situation.
Edited by maxima
hahaha great wall of text :P okay so there would be no point in buying a new engine considering mine could have a bit left in her? and yeah ill definately get her serviced soon oils changed etc
ive got a few pictures already of the sensors but ill take some now and hopefully they wont be too dark...this first pictures of the o2 sensor its plastic clip part is just a bit burnt/cracked im guessing from the turbo so it could possibly still work if i plugged it together and just taped it up, how would i know if its going to root my car being plugged back in? why would they unplug it in the first place lol..
thermo fan, do they just plug into both looms on the front of the intercooler? or are you ment to have 2 fans one for each loom?
ill get a photo of the throttle position sensor being rewired and a intercooler uploaded soon..
heres the throttle sensor picture, if you look closely its apparantly been rewired? why would someone do that when the plug is directly above it? post-93031-0-26948300-1339227262_thumb.jpg
its really hard to show you what i sort of mean with the radiator but there seems to be a larger radiator at the back of the black front one? is that just normal in skylines? ive also noticed though they moved the air conditioning tank? (i think thats what it is lol my bad if not) the picture doesnt really show much but follow the A/C tank back and you'll see the front smaller radiator...
Yeah, smash it in the Forced Induction section.
I would help you out more but I have no experience with turbo motors. I drive an old Rover 216s, it's a nice car, good on fuel but I think it is going to need some maintenance soon and I think it is going to cost a whole bunch of cash because my friend Doreen had to buy a water pump for her fathers MG and she said it was very expensive but she didn't say how expensive so I don't really know what she considers expensive because she has to borrow her fathers car to drive everywhere which makes me think she is poor because she doesn't have her own car.
thanks mate, have it posted in general maintence but should have gone forced induction >.<
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
