We've just fitted the EVC 4, and have a few problems....
1. If I set the High Boost to say 1.1bar, the boost reading goes upto 1.2-1.3, but on the dyno the boost is holding spot on.
2. Had a mate look at the instructions, and he thinks the LOW boost setting is when the controller starts to open the wastegate for spooling & the HIGH boost setting is the limit of boost. I thought he was crazy, because as I understand it, the LOW boost is for ***** driving & the HIGH boost is for everyday driving. But after some testing, I think he is correct, maybe someone can test it themselves? When I set my LOW Boost to eg: .5 and HIGH to 1.1 the boost comes on smooth and early, if I set my LOW boost equal to my HIGH boost, the boost is much more agressive and comes on later.
I'm running HKS Silver Actuators which I believe are .9 ~ 1bar, If I'm setting my EBC LOW Setting below this figure, is it useless having these actuators?
https://www.sau.com.au/forums/topic/40216-whos-using-hks-evc-boost-controller/
I have an EVC 4 aswell. Low is one boost preset(everyday driving) and high is the other. Low cannot be set higher the high setting tho. Boost response is set while pressing three buttons at once and then the screen flashes -L- then you floor it in third from 1000rpm to redline. then the screen flashes -H- and you do the same. Boost curve is then set to optimal and cannot be changed. I have the instructions at home if you want to know which buttons to press i can't remember off hand.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
