Could be something different and is of interest!! Nice call with the road behaviour too!! If there is updates etc and you havent seen us post in there make sure we get a reminder :thumbsup:
So let me see if I got this right
Weight reduction stage one = having a piss
Weight reduction stage two = having a piss and a dump
Is that right?
They are stage 2 & 3, most importantly you must remove the boot carpet! Best bang for buck modification so ive heard :P
Ah okay
So what is it if I remove the back seats as well?
If you go to that level you will need an ANDRA license and parachute from what i hear!
think of the welds on your intake manifold :|
and your floor pan falling out (guess its more weight reduction though)
is that like stage 4? strip the car down to the bare chassis, the motor, running gear and a drivers seat?
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
