Could be something different and is of interest!! Nice call with the road behaviour too!! If there is updates etc and you havent seen us post in there make sure we get a reminder :thumbsup:
So let me see if I got this right
Weight reduction stage one = having a piss
Weight reduction stage two = having a piss and a dump
Is that right?
They are stage 2 & 3, most importantly you must remove the boot carpet! Best bang for buck modification so ive heard :P
Ah okay
So what is it if I remove the back seats as well?
If you go to that level you will need an ANDRA license and parachute from what i hear!
think of the welds on your intake manifold :|
and your floor pan falling out (guess its more weight reduction though)
is that like stage 4? strip the car down to the bare chassis, the motor, running gear and a drivers seat?
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
