I forgot about 3 mainly cause of the big turd that it is
EDIT. Bout the only good bit of that movie was the stuck up blonde getting injured at the start
Oh and trying to drift a FWD Lancer on the docks with expert commentary from the old fisherman
The dirty blond was pretty funny,
I thought they just droped the front shaft out of a ralliart lancer?
Edited by wedge_r34gtr
pretty epensive if its at home? is it 415 or 240?
Either way, I'd say they would have to run a seperate line to the transformer for 3 phase.
Sounds sucky :/ might give that a miss by the sounds of it...
do you already have 3 phase in your switchboard??
do you have rewireable fuses or circuit breakers in your switch board?
if you picture digging a trench from your switchboard to your garage, is it a easy path?
why do you NEED three phase?
these questions answer yours :)
a mate of mine done a uni project on converting single phase to 3 phase power last year.
Uni projects are generally based on something that has already been done so there might be an off the shelf unit that does it
ah yes, keep forgetting your a sparky
I still need to dig that trench anyway as there is NO power there yet... So that's not an issue!!
The hoist I want can be single phase if it needs as they are cheap enough...
if there were no rules and you dug the trench i could do it in a couple hours for ya hah. but im not a tradesman etc etc etc
Well hurry up and get your trade :P
How many wires from the pole to the house?
Is the tyre machine cheap enough as in a couple of hundred or is it more than that?
Also be very careful what type of arm it has as some can move when taking off or fitting tyres and can scratch rims
Also a good idea to have one or two 15 amp outlets in a garage as well for welders or compressers if needed
EDIT just my 2c worth
Edited by m.j.h
ahh but you overlook the etc etc etc haha.
i get my trade in december then ill look into getting everything i need to do it for you!
At the rate I work it'll probably take that long to dig the trench :laugh:
Yeah hopefully I can keep chipping away at debts and then be able to afford to wire up the shed and ONE day get a hoist so it makes it easier to work on our cars :D
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
