Sounds like a nice list of parts
What turbo/s you going to run?
Come along on the 26th anyway doesn't matter what car we will only be doing the speed limit anyway
for the moment its going to stay stock turbos and ECU, dont have the cash to do the turbos and an ECU, i will be putting a set of HKS turbos in once i get some money and doing an ECU.
i dont have a car at all till i get the GTR back, she is daily driven :D if all goes weill i can pick her up on the 25th and go on the 26th tho, block is appart and being done as we speak, i totaly destroyed the 3rd and 5th bearing :whistling:
... block is appart and being done as we speak, i totaly destroyed the 3rd and 5th bearing :whistling:
Now me and the mad sceitist have to pull apart the block...sorry couldn't help it.
Its kind of a like a expensive safety feature with these cars...you'll get oil starvation and destroy the engine long before you loose grip...i still would have liked to see a larger sump on this build list for added protetion, but just make sure you overfill it by a 1L.
Also, make sure your builder cleans and checks everything throughly...you don't want to be pulling it apart again in 3 months cause of the bearing shavings floatin around in your block have destroyed the rings or something else....
Damn, thats pretty quick... cruise on 26th if you can make it...i don't think mine will tuned by then, but i might see if i can jump in with someone.
Sounds like a good plan
Motor should be well and truly run in after a cruise, just don't do to many freeway miles at first as the freeway and fresh bores are mortal enemies
LMFAO thats gold.
I dont have the cash for the sump and NItto pump could only do 1 or the other, im going to be using a stock oil pump with a set of reimax gears in her, the ballfes should deal with the oil starvation issue at hand with the restrictor in the head, its going to be my daily till i pay it off (1-2) yrs and after that ill do the sump and big oil pump and turn her into a monster.
From all the shops i have spoken to they all seem to think i will be fine with the OEM pump and gears as long as im not reving out to 10k rpm or anything crazy like that constantly. Ill be doing the 1L overfill also, btw what oil do you guys find to be the best for the GTR?
Edited by T4NK
Hey guys, for those of you that dont know.... My clutch is now toast :P Didnt think it would last long at the power level considering it was way outside its happy zone!
Should have been double clutching not granny shifting :D
ANYWAY, that puts my car out of contention for the 26th as Jim Berry will be working his magic on my clutch around then.....
Ill still probably jump in with someone tho, CHOOKIE???? :woot:
LMFAO thats gold.
yeah fair enough - should be all good
redline is the best, but you can only buy that in drums. Royal Purple or Motul 300V fully synthetic are the other great alternatives. 10-40w should be good for a daily driver.
lol...i was sort of wondering how long your clutch would last. Don't get me wrong - it still sucks that you toasted it. JIM's fully monty clutch is magic - zero slip.
My clutch & new flywheel ahould be leaving JIM's today - its a little different as its its a dual carbon clutch - superlight and responsive, but you actually need to slip it to put enough heat into so it actually grabs whens cold. It was a bit of a prick to get up steep driveways etc when the car was cold - JIM's almost doulbled the clamping force, so hoperfully it will be much better.
Yeah it was going to have a limited life which we knew from the start, makes me wonder if it has been slipping during the tune etc? Will find out i guess!
Mine is a sort of custom setup too, he said it'll be better than the full monty :D he was saying he does a bit of work for Paul.... Didnt realise he was meaning yours lol
The clamping force on mine will double over the Excedy button which should be pretty impressive! He said the heavy flywheel was the way to go for me, why did you go light?
my car's penciled in at JEZ's for a tune next friday, and cold start saturday...so at this stage i will be making the cruise if all my parts arrive and theres no hipcups etc My biggest concern atm is my injectors (only 600cc)...expecting to crack 400awkw (more hoping lol, just to say i cracked 400awkw - expecting more around 380 on finaly tune, i'm not going to be disappointed either way) so i should be pretty much at the limit for these injectors on paper.
so if everything works out, someone can jump in with me.
Dont you need a run in tune first? And 600cc? Really? :/
400 is a nice number ;) I will head there once i clear some debt, but mine will be RWKW for the skids! haha
that will be an impressive clutch lol - I actually didn't know i had carbon clutch till we pulled the engine out - was a nice suprice and explained the slippage. The hole clutch package (minus fly) only weighs like 3kg - much lighter then a normal twin. I just told JIM to machine me a billet fly wheel to match the clutch..so i don't know what i ended up with TBH.
I got the as part of a package deal from the US last year when i was going to do a -9 setup - brand new nismo MAF's, new injectos, midori modified intake pipe and nismo front pipe for $1200US - was pretty happy...although i sold the front pipes, not using the twin turbo pipe, going for a map tune (no mafs) and the injectors are probarly to small.
Whats this place. Ello peeps
ahh outsider :domokun: :domokun: :domokun: :domokun:
Edited by wedge_r34gtr
keep me posted mate if your offloading some parts, im going for a -9 setup so could be interested in some etc..
Yeah after a long long long conversation yesterday i learnt HEAPS about clutches and flywheels etc...... Lighter not always better, well rarely better in a lot of cars lol!
Dont run 600's man, you will only regret it and have to change it at a later date, do it right the first time :)
LOL, outsiders are OK, them wasteland boys bring the lulz :D
jim likes to talk clutch lol
...i'll make a decsion tonght. might see if i can pick some Id1000/2000 in sydney tomorrow
yeah only playin around..don't get to play in the wasteland that much due to NSFW...i'm basically on my work connection all the time atm :verymad:
You'll probably kill the diff or driveshafts next LOL
I'll have a spare seat but might be a tight squeeze in the back of the car, though driving chooks does sound like a better plan
Jelly
He does, awesome bloke to chat too!!
Yes big injectors! Doooo it!
Yeah I'm on at work or my phone, wasteland is awesome haha
Haha nah already did that with 250kw so it's all replaced :P
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
