Yea it's all preference mate, depends if you like more linear power or a harder pull etc..
I'm so keen to squeeze a little extra power from mine in a few weeks, will post results once done
please do :-)
what did you replace your pods with? and what else are you doing?
please do :-)
Putting stock airbox back in, then doing boost controller to up to about 15-16psi (from stpck 13psi) and adjustable cam gears.. So just finishing off the first stage...
I'm hoping with a good tune it will be more responsive and get somewhere in the realms of 230-250awkw... Would be very happy with that, not winning any power records, but will be a good improvement I think
I passed a parked mx5 and spat flames going from 2nd to 3rd and the thing lit up like a xmas tree, alarm was going nuts lmfao.
Haha nice ;)
thanks for coming over guys,
so the 21st, whats happening???
Thanks for having us
Not sure what's happening on the 21st, he'll I'm not sure what happened half the night
I do remember breaking my phone and moving your car but the rest is lost in the fog
chris reminded me i hammer throwed a loaf of bread onto my neighbours roof lolol
Quickly followed by you falling on your arse ha, was such a funny night! Thanks for having us...
Martin, have you put in the name change request? Hahaha
Not sure about the 21st? Not sure if we came to a conclusion? Old pac?
i got a thirst that needs quenching!!!
keen for brews!
Thinking the same thing
Im looking forward to a few drinks
Am on babysitting duties at the moment but after that drinks will be consumed
This sums up the night had ----------------------------------------------------------------> :laugh:
:laugh: and then Chris replicated it!
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
