Yo Chookie chicken, you keen for pies on the weekend? We may need to scout this 21st cruise route as people are concerned about the ferry so i am thinking we repicate the run and see for ourslelves before i post up all of the details in a thread.... Let me know if your keen? I dont wanna post it up without knowing what its like!
See that truck thing coming up Wednesday on One HD? Looks alright!
No but I'll check it out
On a different topic I dropped the truck off to get some work done under warranty. Mainly a new headgasket as the bolts have streched and it leaking coolant
I ask the service person if they got new headstuds for the job and they say no we will use the old ones they should be alright
I thought all headbolts were a single use thing these days so will see what happens
Looks interesting! I like seeing shit built :D
I would be replacing the head studs if it was my car but depending on what the workshop manual says on those things will determine what is replaced under warranty as its all by the book!
But seriously IF the leak is due to bolts stretching why the f**k would you re-use them? lol :no:
Wow, thats been a while man! I would PM one and ask if everything is OK?
I am sure mine went through pretty quickly.... Its copped a hiding today :woot: Pic dump followed by chat......
Its odd that you've had no reply, the guys are normally pretty good.......
Ash is up to his eyeballs in SAU Nats so not sure how you will go there, although he is generally awesome too :D
Oh and the job on the truck turned to shit as well
I wanted to get it done in a weeks time when I'm on holidays so if anything went wrong it wasn't a problem but for whatever reason the boss wanted it done today and pick it up tomorrow
I get a phone call that it won't be ready till Friday and the boss hits the roof, en result was it got put back together before the head came off and will be done when I'm on holiday
Is everyone's car under cover
Looking nasty weather wise
Yeah, it's been under cover for too long :/
You should see the pics Sean posted up in the members thread!! Snow/hail :blink:
Damn
Where's he at?
Oh and I would come with you guys on Sunday but unfortunately I'll be outside fishing
On a unrelated note I went to the BP near work this arvo for fuel and the young bloke behind the counter says
"I was wondering who owns that car. I've seen it in the car park and a mate of mine owns 33"
Was a bit surprised as I don't think the car gets noticed that much
Anyone think the below is too much stretch? Looking at the same tyres as the wheels on the left, which are the same width as mine...
Thoughts?
http://www.modified.com/projectcars/modp-1010-mitsubishi-lancer-evolution-x/photo_17.html
Thoughts?
http://www.modified....x/photo_17.html
thats stuff all stretch ant dont think it is to much at all
not like your an idiot like me :) 225 on 9.5"
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
