Ahh I remember the day when that used to be a big number.. Everyone I know is running 400+ these days
(no offence of course)
Nah none taken, i know it's 'under powered' these days haha.
I was hoping for 230+ with my setup so I'm happy, just waiting to drive it now
Nah none taken, i know it's 'under powered' these days haha. I was hoping for 230+ with my setup so I'm happy, just waiting to drive it now
I'd be lucky if I'm even making 150kws on the poopra..
It needs some overnight parts from japan
Do you think if I take the spare wheel out and remove the carpet, rear seats and all the trim the power to weight ratio would be better? In effect wouldn't that give me more rwkws?
Need to buy some new plugs and need a fuel reg atm..
what an essay
It was ready to go this morning but i forgot to click the GO button! :P
Is it detailed enough? We will get better as we go i guess! I was going to put up more of Chookie but didnt want to scare people off :D
Cruise Cruise Cruise :banana:
Alright lads, one of my boys got me a hookup when he took his supra down to team K Kustoms for a tune up and took some pics of my car for me, here is what she looks like with no engine.
That first shot is about as far off the ground as Jarrads car :laugh:
Looks good mate! Make sure its ready for the 21st as it is all a go!
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
