On that note, where the fark is Chookie? :blink:
still breathing
fucing 2 jobs is the worst for any time to play with cars or myself ;)
also jarrad when can i come buy my car bits off you :)
thinking i need them parts for a goo fast run up sugy again :D
still breathing
You hoon! :P
today? tomorrow? now? you white boys work fast, eh?
you still working at officeworks?
LOL i even had the correct voice while reading that!!!
I need to take my car for a drive sometime tomorrow... been a fortnight!
I know that feeling!
Hi guys anyone upgraded there diff in there 34 if so how much and what did you do?
Yes, $600 for second hand Nismo centre, $350 to rebuild and reset as 1.5 way!
There is a guy that had one on Ebay for $300 with $50 postage but it was Kaaz 2 way, a little louder than most but work pretty damn well!
who doing the next cruise? people from work keep asking me what's going on
I'd say putty was a success :P
chookie or Martin?? suggest some dates and routes??
If you leave it to Chookie he will end up Routing Dates :P
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
