Started a thread a while back, but the layout got f**ked up and no moderator would help me, so i started a new one
This was my series 2 silhouette i owned for 4 years, which is now going to scrap metal
This is when i first seen it on carsales, i bought it off a turk from melbourne, he had a bum bag and left 2 points of speed in the boot
and also left oil out of the gearbox so an hour and a half outside of melbourne the gearbox didnt want to work anymore
when i got it rego'd
different grille
first wheels
So anyway i had a bit of a bingle, and it sat for over a year and i decided to strip it and send it to scrap
All going into this girl here, originally owned by fatz on the forum
heres a couple of pics
Specs on the car will be
R31 GTS1 number 164
Standard bilstein suspension, revalved to 90/10
Front and rear whiteline swaybars
Cazman adjustable caster rods
Adjustable panhard bar
R33 twin piston brakes with QFM pads
RB26/30 motor
HKS 272 cams, 10.08mm of lift
Race ported head
intake squish pads removed
HKS bronze valve guides
HKS valve springs
HKS adjustable cam gears
Nitto I-beam rods
Nitto/JE pistons
ARP main studs
ARP RB26 head studs
Nitto oil pump
Larger sump made by ariel at redstar fabrications
CPC new design plenum with billet throttle body to match
CPC billet fuel rail
All alloy cooler piping made by ariel at redstar fabrications
Ebay water to air intercooler
All pipework will be joined by pegasus clamps
Trust/greddy twin T67 manifold, work of art
Twin trust/kinugawa TD06's with surge ported front housings
HKS 60mm wastegate
2 speed powerglide adapted to RB with 5500 stall
B&M scatter shield
B&m pro ratchet shifter
yella terra flex plate
Will build a massive single piece tail shaft to go from the glide to the borgwarner diff
31 spline moser billet axles
Romac full spool
Bosch ID2000 injectors
Aeromotive A1000 pump inbuilt into an aeromotove 75 litre fuel cell
Turbosmart fp1200 fuel regulator
All steel hard lines for the fuel with braided lines in the bay
Link G4 plug and play for a gtr
Racepak digital dash
All i can think of for now, i have about 80% of the parts sitting there ready to go
Car is engineered and will be driven on the street all the time
will have more updates in next few days
Got some more pics, motor bits will be taken up to sydney in a few weeks to machine by gerg up above, he will put pics up as he is doing it im sure!
heres pics if the W2A dummied up in bay
looks like we will have to do some cutting to move the radiator forward and will have to run some thermo fans
and picking gts1 up tomorrow !
bit sad to see the old silo go, but gts1's are the bomb :)
+ as it's one of fatz', it'll be used to hard launches lol..
where are you getting the mani coated and how much is it?
  • 1 month later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
